gutted uppipe EGT BUNG!
Old 12-20-2003 | 11:23 PM
ScoobyBoy's Avatar
if anything you can just slap on the sensor for now and put on the resistor mod until you find the right nut.
its hard to find that nut. the best places to look for are the mom and pop stores.
gluck
Old 12-21-2003 | 01:36 AM
mario's Avatar
I had a gutted uppipe for abot a year w/ the sensor in there and had no problems. i even put an aftermarket upipe in and still have the sensor in, thats about 15,000 miles with the sensor in a gutted/aftermarket uppipe. But when i do my turbo swap im gonna just cut off the sensor and put the 2.2 ohm resistor on.
Old 12-21-2003 | 03:16 AM
AzN121184's Avatar
Car Info: civic
i did the same as mario, i cut off the sensor, still plugged it into the aftermarket uppipe just to cover the hole. bought a2.2k resistor pack from radio shack for a dollar, and ive been driving for 2000 miles no problems
Old 12-21-2003 | 05:27 PM
mario's Avatar
Originally posted by ****
when u gut ur pipe, don't u already need a 2.2 ohm in place?
Nope im running a helix uppipe w/ a flex and no cel from it at all been like that for atleast 7,000 miles. :banana:
Old 12-21-2003 | 10:29 PM
Uncle Scotty's Avatar
It is a 2200 ohm resistor....
It is a 2.2K ohm resistor.....
It is a two thousand two hundred ohm resistor.
It is NOT a 2.2 ohm resistor.....DAMN IT.
And if the bolt only threads in 1/2 inch and stops, ya got the wrong bolt.
The stock probe WILL fail, just give it enough time and it WILL fail.
Old 12-22-2003 | 02:51 AM
mario's Avatar
So Uncle Scotty Which resistor is it??
Old 12-22-2003 | 03:45 AM
Ok...so I never f'ed with the stock UP....if the bolt only threads 1/2" then ya better use some sort of JB Weld or whatever on it, or it's gonna back out on ya. Hell...tack weld it to the bung would be best, after it is torqued down good.
And, Mario....RTFP.
Old 12-22-2003 | 03:30 PM
verc's Avatar
Car Info: GT35R, Meth
hey wait I'm confused....
So I just need to go to radio shack and get a 2.2k resistor, solder it inline with the probe, and it'll be all good for the rest of eternity?
Or do I actually have to remove and plug it up?
Old 12-25-2003 | 12:27 AM
verc's Avatar
Originally posted by hackjar
You need to put the 2.2k resistor inline with the harness that is connected to the car not the half of the harness connected to the probe. You don't even have to solder it, just disconnect the probe at the harness and slot the wires of the resistor into the two holes on the car-side harness and wrap it up with electical tape. Remove the egt probe from the pipe (with it's wire and harness) and put an M12 x 1.25 bolt in its place. Torque it down to 30lb-ft and you'll be fine. Trust me, it will not come undone and there is no need to use a thread lock or other glue, it would burn up due to the heat anyway.
O ok, so this is at the ECU where I lift up my passenger floormat right?
Is there a diagram somewhere? I have the fsm
