Green bracket for FUEL pump
Anybody have experience with the TurboXS stage 4 build with changing the fuel pump will know that they recommend unplugging a green relay bracket from under the passenger side kick plate (to ecu).
Ive got an 04 and cant find what they have in the picture, but I have found 2 other green brackets. One with only one wire, and the other back farther with 4 or 5 in it. Its close to a big brown bracket.
Does anyone know where this "bracket"/ harness is. Does anyone know a better way to disable to fuel pump?
I appreciate the replies,
Chris
Chris
Hmmm I don't recall which you are refering specifically, but there is a green harness just infront of the passenger door, to right of the passengers shin bone, just below or at the bottom level of the glove box that is the fuel pump harness. The might be referring to an actual relay that is somewhere further up the line. I don't see why you couldn't just disengage this harness instead.
jason
p.s. I don't know how many times I had to correct "hardness" when trying to type "harness".
jason
drifter04
11-05-2008 10:38 PM
dan2304k
Wanted
05-25-2006 04:28 PM
ImprezaRSX
02-03-2004 02:09 PM
JohnB
06-30-2003 12:14 PM
