Glowing Turbo!?
Old 08-13-2004, 12:14 AM
Littleboyblue's Avatar
Glowing Turbo?!
I went on a drive with my friends last week through the mountains. We stop occasionally on the drive to cool down the motor and the brakes. My friend, who has a turbo car, told me to pop the hood to see if the turbo was glowing. Sure enough when we stopped and looked under the hood, the turbo was glowing. Tonight I drove home (30 min freeway drive) only going about 70mph, and when I got home wanted to see if the turbo was glowing. And again it was. I was just wondering if this is normal?
Littleboyblue is offline
Old 08-13-2004, 12:22 AM
A 04 GUIZE's Avatar
Car Info: 06 EVO IX 67 COUPE DEVILLE
well my buddys evo glows when he dyno's but thats a lot different casue theres not really forced air being ramed in.take a pic i wanan see it hehe
A 04 GUIZE is offline
Old 08-13-2004, 12:25 AM
RoadSpike's Avatar
Thats why it has oil lines, and is made out of cast iron.
RoadSpike is offline
Old 08-13-2004, 12:40 AM
AzN121184's Avatar
Car Info: civic
i want to see a picture too
AzN121184 is offline
Old 08-13-2004, 12:56 AM
I will post pics asap!
Old 08-13-2004, 12:59 AM
It takes a lot of heat to get metal to glow. I know, my father owns a steel construction company. All of that heat has to be some what damaging to the turbo and shorten its life span. I know that the Pre Cat causes a lot heat, I wonder if I was to get an Up pipe, if that would help with heat reduction?
Old 08-13-2004, 01:13 AM
wrx10404's Avatar
Car Info: 04' wrx
I think it's normal on a turbo car, i think it even happens to N/A cars with headers. It's made of cast iron which reacts well to the heat and cold. Should be ok though. Thought: Your ehaust manifold is also made of cast iron. It probably glows when relly hot too. That is why when you are drilling your manifold foor an EGT probe you need to go slow as not to crack the cast iron because all of the hot and cold can make it brittle.
wrx10404 is offline
Old 08-13-2004, 01:35 AM
RoadSpike's Avatar
Yes it does take alot of heat and the fact the turbo cuasing a lil back pressure only adds to how fast it heats up. Its probably getting somewhere around 600-700 degrees F as a rough guesstimate.
the up pipe without a cat should reduce the heat only marginally.
As for your turbo life i wouldn't worry about it. The fans i believe are coated to pervent damage by the extreme heat. Which makes me wonder, if we coated the inside of a turbo with jet hot i wonder if it would be more effecient.
Old 08-13-2004, 01:36 AM
dynamicprojeKtz's Avatar
oh oh i want to see pics toooooooo.
dynamicprojeKtz is offline
Old 08-13-2004, 09:30 AM
mmboost's Avatar
pics? just go do it yourselves. when I had a td04, after a night of mountain driving this would happen all the time. now i just wonder if my vf34 does this
jason
mmboost is offline
Old 08-13-2004, 09:43 AM
ish
ish's Avatar
cast iron is brittle as it is regardless of how many heat cycles its gone through. that is a natural property of cast iron
ish is offline
Old 08-13-2004, 05:10 PM
Choku Dori's Avatar
Location: Under your bed, in your closet, and in your head
Car Info: Corvette Z51
I don't think it should be anything to be scared of. I mean, the brake rotors glow after awhile too ya know!
Choku Dori is offline
Old 08-13-2004, 06:25 PM
But when the brake rotors glow, it usually warps them. My friends car has coolant lines running through the turbo. There is got to be a way to keep the turbo cooler. Maybe with the combined effort of I-Club we can figure out something
Old 08-13-2004, 10:35 PM
pbchief2's Avatar
Car Info: 1995 Impreza L
Your car also has coolant lines running through it
pbchief2 is offline
Old 08-14-2004, 01:33 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
i've seen my turbo glow on several occasions, and the plastic under the exhaust manifold melted.
WindingRoad is offline
Quick Reply: Glowing Turbo!?
