FP20G turbo issue
it's good because:
A: you're subaru comes stock with a water cooled turbo
and
B: A wet bearing housing means it was designed for watercooling
which means
C: You can hook you're water lines up to this turbo
which is good because
D: water cooled turbos last longer, keep oil temps down, and in the case of the WRX, dont require a turbo timer
and
which means
