flat spot under acceleration (was: something is wrong)
something is wrong
Well today when I was on the way to work, I noticed that when I go WOT boost builds up, but before it reaches its peak I feel a bit of a slowdown, and then it pushes on to the top. What could that be?
Origami posted by knele21
What year is your car? What performance mods are on your car? Have you made any recent changes to your car? Omit suspension mods for this topic.
How long has your car exhibited this problem? Does it do the same thing in all gears?
When you say 'slowdown', do you mean that the car actually slows down, or do you mean it momentarily doesn't accelerate as hard as the previous few seconds?
Does your boost gauge register a drop in boost when you feel the car having that problem?
well it's a 02 wrx with a spt catback and accessport. the flat spot happens around 4500 rpm and goes for around 500 rpm before its starts to pull hard again. I haven't noticed the drop in the boost gauge. When I'm at WOT, once I reach 4500-4700 rpm, it feels flat for few seconds. It just started happening two days ago, so I'm thinking maybe something came loose. Thanx for the info!
I can suggest checking underhood for loose intake hoses or vacuum lines that have developed a crack or a leak. The fact that your car recovers after a few seconds and still makes decent power at higher rpm hopefully means it isn't anything really serious. Since you haven't made any recent changes and the acceleration flat spot came on rather suddenly, it might be something that can affect fuel metering under boost. Definitely not normal behavior, though.
Other than that, this isn't something that I've encountered locally in friends' cars.
I'm having the same problem. I emailed the shop that did my tuning and they had no idea. For me, it only does it on occasion and always at 6000 RPMs in both 3rd and 4th gear (haven't tried it in fifth gear).
Mine does the same.... weird. Just like you guys have said before, foot on the floor, boosting as normal then it feels like you have just taken your foot off the gas then stuck it back on again!!
Poor electrical grounding circuit? I've heard that is a common cause of hesitation in the WRX.
and Whitecel,
You're right, the EJ20 does "run out of steam" past 6K RPM and it is due to the small stock turbo.
and Whitecel,
Originally Posted by VRWRX
I've heard it's the ECU switching from open loop to closed loop (or vice versa)???
DerekB707
10-06-2010 09:03 PM
willieb925
01-27-2009 04:11 PM
heat
12-24-2007 07:44 AM
