First mods to my WRX
Originally posted by mike626
Just curious daredevil, when it comes time for smog check, how do you plan to pass it? I live in CA too and im considering going catless as well.
ima switch my stock down pipe and mid pipe when i go to get smogged
Originally posted by neenjafus
do you have to swap the uppipe too, or can you get it smogged in cali with a catless uppipe??
the 1st cat in uppie is not needed since it's mainly used for cold starts.
When smog check time comes, all you have to do is have the car running hot and you'll pass with no problems with the last 2 cats. Only problem may be the visual inspection, which you might not pass if the inspector makes a very thorough inspection.
burnout555
21
11-21-2003 07:07 PM
BluWrX.03
14
04-03-2003 05:14 PM
00b5
03-29-2003 02:00 PM
