Expect gain with Perrin Panel Filter?
Car Info: 04 Java Black Sedan
I searched for this for a while, but was unsuccessful in finding any info. Don't shun me if I have missed something. What kind of gains can I expect with a Perrin Panel Filter over the stock filter, with the snorkle already removed and MBC set to 15 PSI on an 04 WRX sedan?
not too much at all. in fact hardly any. the panel filter is just re-usable and you may claim a gain on the butt dyno. Other than that you get a bit better airflow over stock. I used to have a K&N but went back to the OEM paper filter because i was scared of oil getting on the sensor. I couldn't tell a real difference.
Yeah, by my calculations, assuming a 1000000 mile life on the aftermarket filter, it would save you aproximately 33 OEM filters, assuming you would change the stock filter every 30000 miles. Over the 1000000 mile life that would save you $1000. Hhmmm, that's not really that much. Now, in a more practical example, the aftermarket filter would save us roughly $30. Interesting.
Foam Air Filters
If you get a Perrin Filter, I recommend buying two so that you don't have to wait for cleaning the filter and you can let it soak a day or two in soap and just swap them.
The benefit of a foam filter is mainly due to the fact that they can "pack-up" with alot of material and still maintain good flow. A paper filter is a continuous membrane with little depth versus the porous nature of foam.
Origami posted by stevedood
As for the factory paper filter, it has a large number of pleats that increases the filtering surface area greatly, without taking up much more room. By their very construction, neither foam nor gauze-and-mesh (K&N) can have as much surface filtering area, although square inch to square inch they filter more efficiently.
Vishnu Performance claims that they do not include K&N drop-in panel filters in their WRX kits because the filters lost 2 to 3 horsepower compared with a new factory paper element. While this may be true, the K&N may filter consistently better over a longer period of time while the paper element will probably become clogged and restricted over the same time period. I think the paper elements need to be changed more often than the 30k miles specified in the Subaru maintenance schedule.
Location: Under your bed, in your closet, and in your head
Car Info: Corvette Z51
Foam panel filters are a matter of reusability, like most everyone said. I've also heard that they make the WRX more "drivable" in a sense that the boost threshold is lowered by a bit; that is, the turbo spools a bit quicker. That's about all. So why not, right?
Choku Dori
07-06-2010 07:02 PM
Jake
13
04-17-2007 02:58 PM
kolohe soljah
09-11-2006 12:10 AM
super_subie
12-31-2003 11:50 AM
spdkills
01-29-2003 02:53 PM
