Exhaust smell from the vents
Car Info: Sti hatch
there is this gnarly exhaust smell coming from my vents, when i turn on the recirculating button on it goes away, obviously thats doing its job.
just after i went stage 2 (up dp cbe tmic cobb apv2) i noticed this smell, its especially strong at cold-starts, and at stop signs/lights or any time im just idling and the recirculating isnt on. anyone else have this problem? it smells pretty bad and it cant be good to breathe, CO
thanks in advance
thanks in advance
Car Info: 2002 Subaru WRX PSM
who did your exhaust? I am not much when it comes to these things, but maybe an old gasket was used, and there is an exhaust leak? Probably want to check that out, definitely not good to breath...
Car Info: 04 wrx sedan
is your dp catted? i know thatll make a difference in how much you smell mines got a single cat and i can smell the exhaust (although not all the time, if the windows are down or my door is open i can smell it)
Car Info: Sti hatch
all the gaskets are definately there, i reused all the oem ones so maybe that is the reason. ive changed my dp about 4 times, and im running a single-cat helix bellmouth right now. i just picked up a vf43 so ill go through and replace all those on install.
have to wait to get this cast off my hand... 30 ft kicker + leaning forward = fracture
wal.lin
03-06-2005 03:36 PM
berkasal
14
02-19-2004 11:00 AM
STockWRX
01-09-2004 07:57 PM
808wrx
05-19-2003 12:32 PM
