engine "shaking"
engine "shaking"
I have a 2004 WRX with a few bolt ons(stock turbo). I was crusing around my friends neighborhood and hit a pretty nasty pothole at about 15 miles per hour. about 5 minutes after that i pull up to a red light and i can feel the car start to shake. It's reasonably noticeable at idle, after about 2000rpm it seems to go away. I popped the hood and you can see the motor shaking in the engine bay and definately feel it in the shifter. I'm not really sure what would cause it to act like this and was curious to see if anyone had any suggestions.
our motors like to wobble, its in the nature of the pistons shooting in opposite directions.. unless you went over that pothole hard enough that you damaged or broke a mount (engine or tranny)
well it was actually a mis-fire in cylinder # 3.
the pot-hole jostled the plug wire clip out of the coil pack by just a little bit. So upon first inspection it looked like it was in securely but after i took it off and re-inserted it everything smoothed out.
thanks everyone.
thanks everyone.
thanks everyone.
thanks everyone.
Glad everything is fine now
kimchijeegeah
08-05-2011 06:24 AM
