EJ22T questions to swap into a '01 WRX.
Would it fit into a 01 WRX? Can I put a 2.5 DOHC on top of the block if I can get one? Is there any other fabrication needed to fit the engine? Do I have to bore the cylinders so they match the head? Instead of boring them, can I get a thinner but stronger sleeves to put in? Would any electrical devices in the WRX not work with this engine?
Or should I just work with the ej20t since theirs more aftermarket parts?
Thanks.
Thanks.
Car Info: 92 legacy turbo 5-speed,98forester S 4AT
If you got the money go with the ej22t, it's closed deck, more displacement and IMO the best motor ever made by subaru. I know people have put the 2.5 heads on the ej22t and IIRC they bolt right up. I'm sure there will be lots of issues if you do it. I would transplant the wiring harness too and get an ej22t UTEC from Primitive Enterprises and dump the ecu. The ej22t has a lot of potential but you'll pay to play. Parts are harder to find then for the ej20t (most can be made to fit) but they are out there.
sykosis
06-25-2005 11:07 AM
