EJ20T Limits?
Old 11-23-2003 | 10:05 AM
international B's Avatar
Chewwwwy
i believe the 5mt is the weakest link in our cars. they can hold about 240ish whp before they start breaking. but they dont really seem to be consistant. some people have toasted their tranny in stock form. then again be really careful with the engine as well. i had a ring go bad in cyl#4 and i wasnt pusing much power. i know people that have much more horsepower and run their car leaner and have no problems at all.
Old 11-23-2003 | 10:39 AM
fstbluewrx's Avatar
Car Info: 2010 LANCER GTS
i dont know if this will help but im pushing 290hp and 280tq to the wheels and im having no problems with completly stock internals and trans. I am upgrading the trans over the winter to a
sti 6spd. A bunch of pulls on the dyno and hard runs on the highway and no problems.
Old 11-24-2003 | 07:24 PM
Alan.Whymant's Avatar
Car Info: MY04 WRX
Have a look at www.spdusa.com ....it's got a good explanation of where the power limitations are.
The Prodrive Performance Pack (PPP) sold in the UK takes the engine up to 260 lb-ft of torque and you get to keep your warranty - shame Subaru of America doesn't have anything similar over here.
Old 11-24-2003 | 10:47 PM
Prodrive Power Packs are warranted for parts only, by Prodrive. They are considered aftermarket parts and your warranty can, and most likely will, be denied once they are installed.
Old 11-24-2003 | 11:00 PM
hotrod's Avatar
Trick is in the tuning
The trick is in the tuning. There are a few folks that have gotten up in the high 300 and low 400 hp range on stock internals. This with many drag strip passes and Nitrous. They however tuned the car very carefully and avoided detonation.
Give the car good fuel, and tune carefully to avoid lean out and detonation under high load and you should do okay.
There are folks that have broken pistons on very low modifications so it is mostly the driver, and how the car is tuned.
The EJ20 does not tolerate much detonation. Take care to avoid that and you can make some descent power.
The same goes with the 5MT. There are people that have broken more than one transmission on a basically stock car and folks (see above) that have put mulitiple drag strip passes in the high 11's on the stock gear box.
It is not so much fragile as that it does not let you get away with many mistakes.
Larry
DesolationSuby
04-13-2006 02:59 PM
My_Red_Suby
22
10-26-2004 10:24 AM
Xarch20
04-23-2004 04:56 AM
turborambler
02-28-2003 12:36 AM
Kevin M
102
01-28-2003 11:21 PM
Quick Reply: EJ20T Limits?
