dyno sheets
Old 01-03-2004 | 02:39 AM
woa im gonna be going to hawaii on the 6th of january. there are sheets on small vs big turbo like no other but not NA that i have seen
Old 01-03-2004 | 03:12 PM
McBain's Avatar
Car Info: WRX Shooting Brake
Here are the results from the Subaru Dyno Day at KTR Performance in Ayer, MA. http://www.ktrperformance.com/galler...main_11_22.htm
It lists the various mods next to the dyno sheets. You can compare stock WRXs to modded ones. I doubt you'll be able to find a dyno sheet from a WRX without a turbo. You-know-whose 2002 wagon that's third from the top is particularly mean.
Old 01-03-2004 | 04:14 PM
Wingless Wonder's Avatar
Origami posted by EJ20T
i am doing a science fair project on turbochargers...... can somebody hook me up with any kind of dyno sheets or some links...
Bear in mind that results between two different dynos or even the same dyno on test days with greatly different temperature conditions or altitude can have a noticeable effect on the results. The graphs and numbers often cannot be directly compared unless the same car was run on the same dyno, under similar weather (mainly temperature) conditions.
Old 01-04-2004 | 03:25 PM
Daredevil's Avatar
whast the rs vs the wrx in hp ?
tahts turbo to non turbo..
Old 01-06-2004 | 09:28 PM
sdwrx's Avatar
I would visit www.vwvortex.com and look at the VR6 before and after a turbo... there should be plenty of dyno graphs floating around there if you do a search......
Old 01-14-2004 | 05:07 AM
Kosoku's Avatar
You could do the RS to WRX comparison but its not really gonna be accurate because the RS is 2.5l. Why dont you compare an FC3S(2nd Gen RX7) they have an N/A and a Turbo model, both with a 1.3 l rotary.
Old 01-15-2004 | 01:35 AM
SsTiNgEr77's Avatar
Car Info: 2002
wtf
Wow after looking @ all those graphs and mod lists for each car... i am VERY skeptical on the gains and torque from mods... because either the dyno is jacked up... or a couple of those subaru's are running like 87 octane... cuz those #'s seem way low...
how can a cars with upgraded turbo's be making only like 30 more hp than cars without and same mods? wtf?
NMZ
05-12-2007 06:26 PM
fenderstrat066
10-30-2006 09:47 PM
FW Motorsports
02-11-2005 01:30 PM
Acadian
10-03-2004 01:54 PM
Ender2664
11-22-2003 12:16 PM
Quick Reply: dyno sheets
