Which DP will work with Borla Hush (Have searched)
It seems that by searching, and reading other posts, i have gotten even more lost. I have heard that the Helix DP will not setup properly to the Borla Hush without some welding (which I would like to avoid). Is there any other downpipe that works with the Borla Hush, while also keeping the cat in place. Thank you very much in advance.
pde dp will fit good on your hush. as for me, i also got the hush with the helix dp and had to have an exhaust shop custom make me a flange with 3" piping. all you need to provide is the dp gasket so they can make an outline of it. make sure flange is 1/2 inch thick.
Well i had a sleeve welded to the helix dp to mate it to the borla hush exausht. It was a three inch sleeve and it works just fine.
Why? Well becuase we didn't want the restriction of that 2.5" flange they give you though it would have bolted right up to the helix downpipe.
Originally Posted by Mister 2
I got the PDE and it mates up perfectly to the Hush. Like myron said, any exhaust shop can make a flat flange and 3" piece to work with other downpipes.
06scooby
10-06-2006 10:47 AM
chocolate
02-12-2006 05:21 PM
airzoom411
08-01-2004 11:36 AM
Crisisback
07-20-2004 08:25 PM
