Downpipe Cat Pro/Con
Car Info: 2004 wrx
Is there a difference in reference of PowerGain and Smog/Emissions test to where the CAT is located on the DP?...
-i heard that the cat is more effectived when its located on the upper portion of the DP instend of being on the bottom half like the Turbosx DP.
-so far im passing the emissions test with a invidia Uppipe w/ stock full turboback. After gettin a aftermarket turboback w/ CAT, will or can i still pass the emissions?
Car Info: WRB WRX 2004
you will not pass the visual but you might pass the emissions. So you may pass and you may not. You will not notice the differnce in catless or catted(on a stock turbo). And yes it does work better when its located closer to the turbo because it gets heated up faster. I think i answerd most of it for you. Just get a catted downpipe and call it a day
Originally Posted by projectwrx
dnot worry about getting a catted downpipe. get a catless downpipe... still pass visual and probably pass emissions, gain more horsepower, and not worry about where the cat is located! haha
To answer the original poster's question, the cat will work more efficiently when closer to the heat source (i.e.: turbo). However, we really haven't seen a lot of results from smog tests with cats in different positions, so a cat farther down the line may work just fine. Vishnu did do some smog testing on one of their Stage 2 cars (VF30, injectors, hiflow catted downpipe, catless uppipe, fuel pump) and it passed the sniffer test.
In reality, if you are really concerned about passing the test (as many of us in Kalifornia are), swap the stock parts back in for the test. You can swap a full TBE in an hour.
wvinfernovw
01-06-2006 08:11 PM
mattr762
01-27-2003 07:45 PM
