Does a Catless up pipe shorten turbo life
Originally Posted by RCFerrara
I've read several places, most recently on MRTPerformance's site (http://www.mrtrally.com.au/performance/howbov.htm), that "turbo RPM is based on a "thermal load" NOT rpm as some people think". I guess I always thought that engine RPM and Turbo RPM are directly related. From what this website is saying, it sounds like heat is necessary. What am I missing here? Thanks.
Car Info: MMVI AW WRX STI
JDM-SAL...the Uppipe "fix" is basically a resistor so you can eliminate the stock EGT sensor. The stock sensor can be reinserted into your catless uppipe, but the community has found that the sensors are very prone to failure in a catless uppipe.
When they fail, you either get just a CEL (for failure of the EGT sensor) or you get a CEL accompanied by "limp mode" (when the sensor fails on the high side, telling the car there is a fire in the exhaust). I got limp mode 5k miles after installing my catless uppipe. It's just easier to plug the hole, and plug in the resistor. The resistor is a 2.2k ohm, 0.5Watt one that you just plug into the ecu side EGT harness. It's a no brainer. Search on clubwrx.net for "EGT resistor mod" for more info.
Littleboyblue: I think you've proven in most of your posts that you know NOTHING about this car, and you just regurgitate what "you're heard" with the hopes of getting an avatar/higher postcount. I'm on to you!
Originally Posted by Littleboyblue
The precat is used to pass smog. They use it to warm the car during the begining of the smog test. At least that is what I've heard.
-Chris
Hot gasses move faster. They will spool up the turbo quicker.
xhengmanx
09-15-2013 05:42 PM
WorldONE
Engine and Drivetrain
07-24-2007 12:01 PM
GO24JUNIOR
01-31-2004 10:43 AM
