Do aftermarket intakes actually produce power?
Old 12-26-2004, 09:42 PM
oct1285's Avatar
Car Info: iono nemore
i'm sorry but does anyone see the "super charge any car for $69.95" ad at the bottom of the page.
I just find it kinda funny to see that in a thread about whether or not intakes make power
oct1285 is offline
Old 12-27-2004, 01:53 AM
Vendetta's Avatar
Car Info: '02 WRX Sedan 5MT
Believe it or not, I was just thinkin that... haha
Tornado.. what bs.
Vendetta is offline
Old 12-27-2004, 07:11 AM
Donkey's Avatar
Car Info: 02' WRX
Originally Posted by Imprezer
Actually I have heard very good things about Injen. I will try to get my hands on one and test it for you guys.
The APS and Perrin are supposed to work with out any side effects.The problem is most air intakes use a 3" diameter pipe.The Karmen Vortex style MAF sensor that Subaru uses is different than the GM/Ford hotwire where the MAF sensor is monted in a permanent orrifice and the Subaru/Denso one uses the stock airbox neck as the orrifice(which is like 2 5/8").The Subaru meter has been calibrated to this size orrifice and when you change the size of the orrifice the sensor is no longer calibrated.If the Maf is installed in a larger pipe it will run lean,smaller will result in a richer mixture.The APS and Perrin use the same size dia as the stock MAF location on the airbox neck.
Donkey is offline
Old 12-28-2004, 09:58 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
can anyone verify this information? thx.
XkrazyAsianX is offline
Old 12-29-2004, 03:22 PM
Donkey's Avatar
Car Info: 02' WRX
Check the sticky at the top of the page labeled"cold air intake debate".Plus every week this topic is brought up.Plus on Cobb's,Vishnu's,Perrin's...websites there is mention of this problem as well.
Donkey is offline
Old 01-03-2005, 06:00 PM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
yes because it makes you run a little leaner no real gains
Vicore_Wrx is offline
Old 01-03-2005, 08:40 PM
iClub Silver Vendor
FW Motorsports's Avatar
Car Info: 2005 LGT wagon
Here's a good read on air filters.
FW Motorsports is offline
JM Auto Racing
Engine and Drivetrain
400
12-07-2015 07:09 AM
stickercutting
06-27-2006 09:21 AM
pac-rex
10-24-2005 04:48 PM
MPOWERD
10-01-2004 02:41 PM
OakosAutomotive
Vendor Group Buys/Specials
11-14-2003 02:53 PM
Quick Reply: Do aftermarket intakes actually produce power?
Top
