coil packs
Old 09-09-2010 | 04:21 PM
831subaru's Avatar
coil packs
ummm so how is it that you can tell if a coil pack is not working any more...i plugged in my V.1 access port and it shows system to lean and it also says cylinder 1 2 3 misfire on the codes....what can i do to make those codes not show again
Old 09-09-2010 | 04:56 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
miles?
Mods?
Maintenance?
Old 09-09-2010 | 11:54 PM
^All of the above and..
When was the last time you changed your spark plugs?
Old 09-10-2010 | 12:04 AM
831subaru's Avatar
153000
vf34..injectors fuel pump..stage 2 V.1 accesport...STi IC...perrin turbo inlet
oil every 3500 miles...i changed the spark plugs last year in april took them out and re-gapped them in febuary
Old 09-10-2010 | 12:06 AM
I would still take a look at the plugs.. Its the cheapest start to a possible solution
Old 09-10-2010 | 12:08 AM
831subaru's Avatar
ok can that be why my car sounds like if its a stroker....or should i adjust my idle
iaff474
Subaru OEM Parts For Sale
10-09-2008 07:05 AM
diz
03-07-2007 02:25 AM
Project Worx
03-15-2005 12:43 AM
Project Worx
03-12-2005 08:09 PM
East Coast WRX
05-03-2004 10:09 AM
