code p1312 help
Car Info: MMVI AW WRX STI
Heheh, I'll post them here then!!
If you have no other codes...your EGT sensor is bad.
Lemme guess...you have a catless uppipe? Read up on the EGT resistor fix , go to radio shack and buy the resistor, and plug it in. For the best fix, plug the hole with bolt (M12x1.25). If you car is stock, take it in.
-=Eric
-=Eric
Car Info: 2003 WRX Metallic Silver
Originally posted by RacerZ22
if your catless its not that bad just get the resistor and its an easy fix
New2MeSuby
05-24-2004 08:40 AM
