Cobb Stage 1 Cylinder Head Package
Car Info: '02 WRX TurboXS Stage 4
I was getting ready to purchase a UTEK for my WRX but before I do I wanted to see if I could get some feed back on the Cobb Tuning Stage 1 Cylinder Head Package. I realize that the cylinder head is a little over twice the cost of the UTEK but I was thinking it might be smart for me to continue saving and go for the cylinder head. I have heard many people say that the stock turbo has a hard time supporting more than 300 hp and was wondering if this applies to all ways of modification or only when dealing with bolt-ons? Will I need to purchase a larger turbo to take advantage of the cylinder head and If so will that require larger injectors and a fuel pump. I would like to avoid purchasing a turbo as well as injectors and a fuel pump at this time and if I do decide to muve up to a larger turbo I would like to stay close to the stock size but increase the efficiantcy of the turbo for drivability issues,(can I do that without the injetors and fuel pump?). My power goals remain undefined in terms of numbers but ideally I would like to milk as much power as I can from the car with little effect on reliability and drivability. Cobb claims a starting point of 30 additional hp for the cylinder head alone. Can I expect another 30+ from a UTEK if I add the UTEK after the cylinder head? I know very little right now so all pertinent information will be helpful. I am also interested in knowing if the Stage 1 will effect my emissions negatively or has any reliability issues compared with stock. This is just the first step as I am certain more information will lead to more questions so if you can think of any information that I might find useful please include it in your response. I have yet to contact Cobb becuase I would like to know what I am talking about, to some degree at least, befor hand. Thanks
personally i would not go into your motor until you are ready to do the entire project. so far on my car i have done everything you can possibly do to it. i have a fully built 2.5 closed deck with completely done wrx heads. going all the way is a huge project that takes time and money. i would only do the heads if i were going all out on the heads. so if you did want to do the heads, do the stage 3 not the stage 1. if you are going to go as far as talking your heads off, do the entire motor.
just my .02 cents
just my .02 cents
srbaugust
15
06-02-2013 02:02 AM
wombatsauce
04-14-2005 10:30 AM
Silverbullet04
17
05-20-2004 10:36 AM
poostik
24
08-11-2003 09:04 PM
