Catted Downpipes
Car Info: 02 WRX
The Cobb only comes in 2.5" donut gasket, which (unless used with an adapter) will limit your choice of catbacks to virtually only SPT/Cobb/Borla Hush and a couple others in that ballpark. If I remember correctly, the Invidia comes with 3" flange.
Car Info: 2002 Wrx Sedan
cobb also places the cat lower right before the rear 02 sensor. most other (if not everyone else) places the cat on the vertical portion of the dp. the cobb dp also has a 02 bung already made on top for a WB 02 sensor. both invidia and cobb are made with high quality materials, and produce the same power on any dyno, cobb is just a little better engineered. note that you can mate any 3in catback to the tapered 2.5in donut flange no problem, but if you know that you are going to run a full 3in catback, just go with the invidia
The quality and construction of the Cobb Tuning
downpipes are excellent.I know the catted version Cobb
downpipe have a good quality catalytic converter on them
because mine has lasted a long time.The fitment of the Cobb
downpipe is perfect and that is what I like the most about mine.
Speed Element
Engine and Drivetrain
10-25-2006 11:33 AM
gruppe-s
Vendor Group Buys/Specials
13
04-05-2005 05:50 PM
duo
03-10-2005 11:10 PM
gruppe-s
03-10-2005 12:37 PM
gruppe-s
01-15-2005 03:44 PM
