Which cats would pass CA smog sniff test?
#31
Car Info: 02 WRX
So if one were to revert to factory TBE, but keep aftermarket catless UP installed, what would be the proper map to run? You couldn't run the stock map or else you will get codes from not having a cat right? Would AP stage 1 map work? Also, remind me again how many miles you need to drive after resetting ECU in order to be eligible for smog testing.
#33
Car Info: 2015 FR-S
I had a wrx wagon that had a TXS signature series TBE with a HFC. The HFC had about 90k on it when I smogged it, but I had just changed the oil, plugs and filter. After warming up the car, I took it for the inspection and convinced the guy the setup was factor.
He smogged the car, I passed the emissions part, but failed because I had recently reset the ECU and it hadnt performed the diagnostic tests.
#34
Car Info: Legs.
I don't know the smog numbers right off the top of my head, but I know that all of them, with the exception of one, were well under the limits. One of the categories was 1ppm away from being at the max.
Keep in mind that the setup had well over 90k on it, so the cat was likely not performing as well as a new setup.
#35
Car Info: 03 WRX Wagon
Helix Catted DP passes
I have a catted V1 Helix DP and a gutted uppipe, with a ECUTECK tuned by Mike when he was at Gruppe-S.
It passed after being warmed up and run between 2400-2800 in P/N for 3 minutes.
The number's were
@ idle HC measured 16ppm, CO 0.00%, CO2 13.5%, O2 1.7%
@2500 HC measured 10ppm, CO 0.01%, CO2 14.5%, O2 .30%
The cat is 4 years old with 30,000 +/- miles on it
The HC and CO were well below the max
The number's were
#36
Car Info: 2015 FR-S
The number's were
The number's were
My numbers:
@ idle HC measured 14ppm (100ppm Max), CO 0.01% (1.00% Max), CO2 15.1%, O2 0.0%
@2500 HC measured 0 ppm (130ppm Max), CO 0.00% (1.00% Max), CO2 15.1%, O2 0.0%
The car had 117,771 miles with all original cats.
Now I know what catted downpipe I should buy.
#37
I just passed on the second smog test in CA for my stage 2 04 wagon with maddad v2 downpipe catted and sti uppipe. On first the test, I failed the functional monitor test(had a dead battery earlier) and had to drive it about 100 miles to reset the check monitors. Finally I still passed but the HC levels were slightly high: HC max 100 measured at 81-85(second test). I didn't have to change my accessport stage 2 map to pass and I'll probably have to add the third cat to pass for the next test in 2 years. Good thing the price of smog tests is going down if you shop around, as it cost me $18.75 for first test(fail) and $34.95 for the successful test!
#39
#41
Car Info: 2002 Subaru WRX wagon
Jumpin' in late here. Almost 2 years ago my wife brought our 02 wrx in for smog with Cobb tbe, gutted up and flashed to stage 2. Had about 125,000 miles on it. I don't remember the #s, but it passed fine. I wonder how many more of those I'll get?
#42
Car Info: 05 WRX Wagon and 08 Civic Si
ok if your in california you must pass a visual and tailpipe emissions test which means you can fail just by having a modded exhaust system. most smog techs won't fail your visual if there is a highflo cat installed (ask ahead of time or find a place that someone recommends don't pay for a test and get failed by some lil jerk with a god complex ) from what i hear the helix will pass tailpipe emissions as long as your map is done right. now here is the best part, our cars are all wheel drive and smog stations only have a 2 wheel dyno which means we only have to pass at idle and 2500 rpm
just for info my WRX was catless at first and then i went to a helix catted DP and only lost 5hp so its not that much of a loss atleast on a motor producing around 350 hp
#43
Car Info: 2013 SWP BRZ
I was able to pass smog with a stage 2 setup, it included a up-pipe, helix catted dp, catback, cobb ap, and a hallman mbc in terms of emission.
BUT! I failed in visuals..... So in the end i had to put the stock dp, catback, and boost solenoid in order to fully pass...
#44
Car Info: RA Hybrid Bugeye!
i just went to get smogged and failed.. i passed the visual and emissions part but i cant pass the Rediness part.. Oxygen Sensor is Not Ready and Catalyst is Not Ready.. cant understand why...
#45
Car Info: 2002 WRX Sedan, 2004 Acura TL
There might be easier and quicker ways around it. Anyone feel free to chime in.
