Car won't start
Car won't start
Aight I just finished a JDM STI VII swap into my 02 wrx. I go to try and crank it and it turns over but won't start. I swapped the JDM Ecu with USDM wrx ecu but it still didn't work. I changed all the coil packs over and nothing. I changed the Crank angle sensor and the cam position sensor. The fuel pump is coming on there is just no spark. I've checked EVERY fuse in the car and a couple of ignition relays to boot. I checked and all my grounds were good. Anyone have any ideas???
try check connections and power to each coil pack ....... check if u get fuel pressure at the rails, fuel might be clogged before it gets to the rails(fuel filter or lines?) sounds like a fuel problem. tell me what u find. ...... can u access to fault codes? that might help
Car Info: 2004 Impreza WRX
Make sure there is gas in the tank .. LOL
But seriously you said you have fuel but no spark unless I misunderstood you. Your starter is cranking but the engine just wont fire? Are you geting a CEL, because it seems like you may be having Computer Trouble.
peterislazy
08-15-2008 09:32 PM
EddyRS
10-18-2003 01:29 PM
