Car threw a cel today.
Car Info: SGM 135i
Well, it's a misfire in the 4th cylinder. I know my spark plugs are due, could that be the problem? Anything else that i should worry about? Any input's appreciated.
Car: 04 WRX
Mods: vf34, sti injectors, walbro fuel pump, perrin crank pulley, borla headers, helix up and down pipes (catless), borla hush.
Car: 04 WRX
How many miles? I had a misfire code (cylinder 4? dont remember) along with 2 other codes before I had my CEL fixes. This was about ~ 35K miles. My mods are catless up, highflow TBE, IC hoses and ecutek.
A friend told me it was due to the o2 sensors reading to much fuel/too hot...?? Maybe someone can explain it better. I dont know...but now that I did the 2.2k ohm 1/2 watt resistor for the uppipe and mechanical fix for the rear o2 , none of the CEL's have come back. Im at 52K miles now.
Do you have a light flyheel?
Car Info: 05 WRX Wagon and 08 Civic Si
Originally Posted by XkrazyAsianX
i just hit 40k recently, i have the mechanicl o2 sensor fix for the dp, but nothing for the up, maybe i should do that ><
running a VF34 your plugs are going to go alot quicker id replace the plugs and go from there see if it happens again.
Car Info: 06 STI WRB/Gold
Start with the plugs, of course one step colder than stock. Report back if the problem is still there. Check out www.clubplug.net
Keisatsu
02-18-2004 03:13 PM
pyrojohnhippy
13
01-07-2004 12:50 AM
