Car idles funky after long trip.. dies out of gear.. IAC? Front O2?
![Question](https://www.i-club.com/forums/images/icons/icon5.gif)
I've just completed a 1,300 mile trip from CO to CA. Oil was done before trip, plugs still have life and oil levels check out. After day one.. car still ran fine. After day two and upon arriving at my destination the car began to have jumpy idle and would die if not in gear.
It has been pretty hot here, including the day I got in. I'm assuming my three year old Optima red top wouldn't be the culprit. Again the car seems to drive fine when in gear only. All electronics work and the car starts up just fine - it's just when it idles that it has issues. Ended up checking the MAF and air filter - a little dirty, but nothing major. Cleaned both and reinstalled. Car still runs like crap. Just finished up replacing the front AF/O2 sensor per someone's suggestion. No luck. Could it be the IAC...or something else? I'm stumped.
hmm that's real weird. Haven't heard that one before. Well I mean it can happen I guess, stay stuck. Just get another around the forums or on craigslist. They go relatively cheap. I would NOT suggest a BOV as a alternative solution. Good Luck.
Seafoam car.
1/3rd in BPV or BOV vac line (I used a funnel and a cup after pourin 1/3rd into the cup)
1/3rd in oil
1/3rd in gas
Let it sit for 10-15 minutes.
Rev car in neutral for about 5 minutes at various range (3k to 5-6k) leave it at a high rev every now n' then, dont just rev n' let it drop. And watch the white smoke leave ur car
If ur going to put it in your oil, you will probably want to change your oil after ur done. Dont drive around afterwards without changing ur oil.
I did this and my idle went from almost dying/hard idle to a lot smoother n' calm idle.
1/3rd in oil
1/3rd in gas
brucelee
07-14-2009 08:53 PM
Proj.JDM_STI
10-08-2006 01:14 PM
blackwagonrx
02-07-2004 02:17 PM
I-beater
06-19-2003 07:34 PM
