Built 2.4 liter motor, UTEC, now refuses to start
Old 12-06-2004 | 03:50 AM
hotrod's Avatar
trouble shooting
By the way just a tip, your thread title is not going to attract the folks that can give you useful input on this problem -- it should have been something like--
"I need help with a no start problem"
We need a little more info to put your symptoms in context. What was going on a few days before the problems started showing up. How long was the car running okay on the UTEC setup / tune you had when the symptoms first showed up.
What were the last few things you did to the car before the problem showed up?
(I mean every thing -- did you wash it, hit some RR tracks really hard and jump the car -- work on it adding a stereo etc.)
If it has been running fine for a while as currently set up, something has changed.
Trouble shooting a problem like this involves, a systematic process of elimination.
First confirm the basics.
Clean your battery posts and connections --- ( I know they look fine but do it anyway you want to be absolutely sure of some basic facts)
With a volt meter confirm you have adequate battery voltage, so turn on the head lights and see what your battery voltage reads. Then take the same readings at the other end of the battery cables. (IE. with the voltage meter reading one probe on the ground screw the ground cable attaches to the body, and the other to the hot lead inside the main fuse box.
On my car, with everything off, including the ignition the voltage at the battery posts shows 12.66 V. When I turn on the ignition, and the head lights I get 11.8V.
My voltage from ground bolt to fuse box hot terminal is 12.3 V. The 12.66 vs 12.3 readings show the effects of connection and wire resistance to the cars electrical system.
Next clean and re-tighten all the ground straps that connect to the engine block and fire wall in the engine bay.
The odds of all your sensors going bad at the same time without a triggering event like the car getting struck by lightning, or you having someone arc welding a trailer hitch on , or giving someone a jump start and having a hook up error that resulted in a huge spark, is very unlikely.
My guess is that you have a connector that is loose on the UTEC or the ECU. So the next thing I would recommend is that you unplug and then re-seat each of the plugs on the ECU and the UTEC. Same goes for each of the sensors that are giving funky readings on the UTEC.
Larry
Old 12-11-2004 | 09:58 AM
WRXWagon203's Avatar
Car Info: Sold My Stage 4+ Wa-Goon :(
I know it seems asinine.. why don't you replace the sensors.. they can be had for quite cheap at some local bone yards.. just test them before you leave..
Get a buddy and TRACE EVERY wire. I mean EVERYTHING. It takes roughly about three hours to do so with help. I had to do it a few months ago. I had the same issue when I installed my 2.2 way back when I went through my first motor. I Can't exactly say what it was, but I took the painstaking task at hand.. unclipped and reclipped every harness, wire, sanded all grounding points.. and the car started up. Why would the ecu have just 'fried'; did you drop something on it? Did water get into the foot well of your car?
-G
Z Madness
12-17-2010 01:15 PM
greenpoop
07-09-2009 08:31 PM
FLIWRX
Engine and Drivetrain
04-30-2007 01:27 PM
bugeyehybrid
Cars For Sale
11-14-2006 09:48 AM
Marty S
08-25-2003 09:23 PM
Quick Reply: Built 2.4 liter motor, UTEC, now refuses to start
