Boost Levels
Car Info: 2005 STI
Boost Levels
Just wondering if someone could tell me what the boost levels are for a stock WRX in each gear and at what RPM's. For example, 1st gears max boost would hit X psi at X rpm's and 2nd gears boost would hit X psi at X rpm's.
the problem is that i dont really push the car that much but when i do, i dont think i really see the boost gauge hit 1 bar. kinda getting me worried. all i have is an UP, DP, and catback. any help would be appreciated. thanks.
Car Info: 03 WRX / 08 Forester
- Kean
Car Info: 2005 STI
i forgot about the whole altitude thing. well... i just looked it up and the elevation where im at here is 585 feet above sea level. now, i hope that this is suppose to be a good level to be at for optimal boost.
The problem is that i would hit about .7 or .8 bar and then drop down to about .5 or .6 bar and remain there. if no one has any suggestions, can some one provide me a pic of their turbo hoses just so that i can compare with someone elses whos boost level is normal? thanks again.
wonton2049
10-24-2004 07:01 PM
spdkills
12-26-2002 07:33 PM
