Blown up EJ20K
Man, that's looks bad. And the picture looks good.
So, does that mean a bented valve will continue to work
until you push it at a very high speed for a long duration?
scooby5, did you see any symptom before it broke?
Any funny noise? Maybe you can give us something to
look for when it happen to our car.
twlai,
As I mentionned in a previous post, I had "mis"diagnosed the problem to cam clearance. The cams on that cylinder were clicking away a bit too loud so I figured I'd check the clearance and it was off, maybe a bit too off in hindsight.
But I thought none of it and simply swapped the underbucket shims to thicker ones, and off I went... It all went to hell on the highway, I guess the stress on the valve from being slightly bent was enough under higher rev to break it.
I had something like that happen
I got my melted piston pics too, as a souvenir!!!
..there should be a club for this
http://www.imagestation.com/album/?id=4291305785
Pic's are inside, like 4, 5, and 6...
~B
Edit: for URL's
Edit: again, cause I suck!
~B
Edit: for URL's
