Blitz DTT T-fitting Needed! Please Help!
Car Info: 2004 WRX
does anyone know where I can find a T-fitting for this application?? I have tried using a 1/8 fitting, but that's still too big, I have been to Kragen, Autozone, PepBoys, Home Depot, Lowles. none of them have T-fitting that is smaller than that.
Know anywhere I can get this tiny T-fitting??
Also, if someone has this Turbo Timer, can you guys check the part # on your instruction manual so maybe I can get Gruppe-S to order it for me if I can't find it anywhere else. And if you have the instruction manual, can you take some photo of it so I can see it for the installation?
I seriously dont know what to do w/o this T-fitting. =(
-Mark C.
-Mark C.
the 1/8th should fit try pushing the it on there a bit harder.... it worked for me.... i got a 1/4 1/4 1/4 T then a 1 inch 1/4 fuel line and stuck a 1/4 to 1/8 on to it.... (the black T fitting that came with the kit will not work with the USDM car....)
when u get it on u might see that the boost reads are a bit off.... but if their not... tell me =D i'd like to know how to fix mine =)
NGNIOUS
06-25-2003 10:03 AM
Magerum
02-21-2003 09:22 AM
