Best TMIC
Car Info: toaster
Re: Nino's has/had the STI for $599
Originally posted by palaban
https://www.i-club.com/forums/showth...&threadid=3303
bigger is better
http://www.airpowersystems.com.au/wrx/my01/tmic.htm
i believe this one is $760+~$150 for the ic duct (no pic, but needed)
http://www.turboxs.com
this one is $950
this one is $950
First 12sec WRX in HI
Car Info: 12.93@106.71
My MRT TMIC is nice but if I didn't get the deal I did, I'd get the Vishnu. Or just F--k it and go for the FMIC.
With the IC you will definately be the fastest EAT WRX around. Good on ya bro. Now hurry up and get it!
Car Info: First 12sec WRX in CO
Originally posted by Sloppy Joe
It is not universally accepted that the tube / fin design provides superior cooling as compared to bar / plate.
Tom..
Tom..
-Pace
Originally posted by pace
Actually tube-fin do have a tendency for better cooling than bar-plate, and conversely bar-plate have a tendency for lower pressure drop across the IC core. This is just a loose generalization as the design of each individual IC can play a big role. Why do tube-fin provide superior cooling? It makes sense if you consider the higher pressure drop is due to the restrictive flow of this type of intercooler. Therefore the air spends more time inside the IC and accordingly is intercooled to a greater degree.
-Pace
-Pace
Tom..
P.S. Pace I have read a number of your post over on wrxclub.net, ( nice club by the way ) and you would be a great resource to have over here from time to time too..
Hey Tom,
Yup, you are absolutely correct in that it is not 'universally true'. Unfortunately there seems to be limited data showing back-to-back comparisons of pressure drop and temperature differentials of the various TMIC offerings, so we tend to rely instead on the conventional wisdom that generalizes the behavior of the two construction methodologies.
After being torn between a front-mount and top-mount for some time, I finally have opted for TurboXS' revised top mount IC. For me, the minimal pressure drop and lag of the bar-plate in top-mount configuration is a major factor. I already work my turbos harder at this altitude in an effort to achieve respectable MAP levels and I don't want the lag associated with the additional front-mount tubing nor the pressure-drop of a tube-fin. Nathan also informed me that TurboXS' testing of their units show a minimal horsepower advantage with the front-mount until heat-soak situations are considered...
As to why I chose TurboXS; that has more to do with the sizing of their particular unit and the way in which they stand behind their products and make themselves highly accessible for customer support. Just a personal preference, really.
-Pace
-Pace
Hi Pace I totally agree with your reasoning in regards to using a TMIC vs. FMIC, I feel the same why. Actually I am of the belief that too many people are opting for FMIC's as a solution when in reality the big top mounts available now are more than adequate for any VF series turbo, especially with water spray for hot summer traffic or track days.
Take care, Tom..
Take care, Tom..
i currently have a ej20G w/FMIC, i am planing on selling it for a TMIC. i was wondering what is the max hp a sti top mount can handle before it gets heat soaked. eventually i plan on making about 350awdhp will this IC hold up to it? or would i eventually need get a new top.
just wondering (as you can see from the pic above) where do you all supose the heat from the turbo is going??? if you look at the stock air diverter, it is designed to force air down to the turbo and direct heat away from the intercooler area. now with a wider top mount which completely covers the turbo, how is the HOT air given off from the the turbo supposed to be diverted and not simply heat soak into the extended area of the intercooler?
WRXGONE
11-26-2004 12:11 PM
iNfEk
02-16-2004 01:16 PM
K2Skier
03-29-2003 07:00 AM
