best streetable turbo...
Car Info: '03 PSM Sedan
deadbolt ported stock turbo, or a VF23/24.
i have a deadbolt unit, and it works quite well. boost comes on nice and early, enough so that i can often get away with using second gear in hairpins that i used to have to downshift into first for. without upping boost, you won't see much of an increase in peak hp, but you'll get a much broader powerband. you can run this with the stock ecu and injectors easily (i am right now), but to get the most out of it you'd need a reflash and STi injectors.
the vf23/24 are two of the quickest spooling VF series turbos, they'll spool just a bit later than a stock turbo. deadbolt can port these too, to the tune of like $200. i've heard that you can run these with he stock fuel system, but i don't think i would. you'll get more peak power here, but i don't know as much about the width of the powerband.
Former Sponsor
VF34 is my favorite performer for the all round WRX. Plenty of pull around town and nice performer at the track/strip.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Mike
(510) 487-4447
If you could find a nice, cheap, new VF23 to have P&P'd THAT would a real good upgrade, I should think, too You'd need injectors, a pump and EM for that one, though.
i'd thought about going with a P&P VF24 before i bought the deadbolt TD04. i didn't have the cash to throw down on injectors, pump and EM all at once on top of the turbo. if i had, thats what i'd be running. from all the research that i did, that combo should give you one hell of a bump in midrange hp and torque.
Former Sponsor
Clipping turbo's is generally not a good thing to do it may add some increased flow potiential but will take away from the overal efficeincy causing lag.
Mike
(510) 487-4447
Mike
(510) 487-4447
No lag here...The P&P more(far more) than makes up for the bit of clip I almost never wait for boost, and it does a great job of holding boost a lot better towards redline which is the best benifite of the clip.
A big, broad power band is what I've got
Former Sponsor
Glad it works for you, a better actuator would have held the boost till redline though then you would get the benifits of the porting not countering the ineffiecency of clipping.
Mike
(510) 487-4447
Mike
(510) 487-4447
