Best Oil Filter?
Old 11-06-2003, 03:17 PM
NewShockerGuy's Avatar
Arrow
Welp just got done changing the oil... I looked at the fram and the top part where the seal is, is concave in shape where as the OEM one is convex...
I have NO CLUE what that means, or if there is a difference on how the oil is routed through the filter...?
One more question, on the metal gasket that you put on the drain plug, which side goes where... I put the FLAT side to the nut, and the small hump towards the oil pan.
I actually like changing the oil... I need to get jack stands so I can jack the whole car up... being 6'1" and having long arms it's hard for me too see under there with out completly contourting myself everywhere...lol
I actually just ordered one of these:
http://www.fumotovalve.com/
It's a fumoto valve... Looks awesome to me, should cut time by half at least in my opinion... I ordered it from Lubespecialist.com/fumoto so I'll post my opinion of it :-) Kinda sucks that I won't get to use it until 3000 more miles...bla!
-Nigel
NewShockerGuy is offline
Old 11-06-2003, 04:18 PM
jreat's Avatar
Car Info: 2002 WRX and 2001 Mercury Cougar
I wish Mobil1 made one. I use them on my Cougar and they rock. I have used Bosch and it seems to work good.
jreat is offline
Old 11-06-2003, 06:15 PM
Chewwwwy
international B's Avatar
the fram filter has a smaller diameter and it longer, just makes me nervous to have that hanging down that low, when every other filter manufacturer makes one the proper shape.
international B is offline
Old 11-06-2003, 06:19 PM
Salty's Avatar
Originally posted by Jgrahn555
Use the OEM filter.
if not, get puroilator (they make the OEM filter i believe) or mobil1
Salty is offline
Old 11-07-2003, 05:52 AM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
as far as tranny noises go, it's about the same. THe forward gears due seem to slide in better. Yes, i went with the 75w 90 max gear oil. It still whines when even out of gear and slowing down.
ScoobyStas is offline
Old 11-07-2003, 02:26 PM
Uncle Scotty's Avatar
Many who have changed to syn in the trans have loved it for a few thousand miles and then had the problems. The front diff is a part of the trans, therefore cannot use a seperate lube. The rear diff should be able to use a syn lube without problems.
I just changed my trans lube to a 'cocktail' of 3 different products and after no less than 5k miles or If I have problems will I publish my results.
I use Mobil 1 in 10w30(Florida temperatures don't require a different summer/winter oil) and OEM or Purolator oil filters. I change filters at 4k miles and top up until 8k miles and then do a full oil/filter change.
IMHO, changing syn oil every 3k miles is pouring $$$ down the drain
Uncle Scotty is offline
Old 11-09-2003, 04:19 PM
02wrbluewrx's Avatar
Car Info: 2002 WR Blue WRX
Ya why doesnt mobile1 make an oil filter for our cars....kinda disappointing.......anyway right now i use mobile1 oil and a bosch filter seems to be doin the job
02wrbluewrx is offline
fd777
06-12-2010 09:05 PM
JackHCChen
11-12-2005 09:50 PM
wrxout
10-26-2005 03:13 PM
generalwrx
14
08-29-2004 07:47 PM
rustokman
22
03-14-2004 06:43 PM
Quick Reply: Best Oil Filter?
