Back to stock 04 still wont rev past 5g
Old 11-15-2004, 08:14 PM
SilverRex04's Avatar
Car Info: 04 Sti swap, VF22 18psi, 255l fule pump,ecutek 93 oct, Full exhaust TXS, Sti ra gears, much more...
Question Back to stock 04 still wont rev past 5g
I only had a bov, mbc, cai on the car it stopped boosting past 8lbs. one day. I put the car back totally stock and it still wont rev past 5000, idle's like crap,and wont make more than 10 lbs. of boost at any rpm. I reset the ecu. Anyone have any ideas??? Thanks Tom
SilverRex04 is offline
Old 11-16-2004, 11:46 AM
RussB's Avatar
Car Info: $200,000 sports car
how much boost were you running?
RussB is offline
Old 11-16-2004, 01:15 PM
I was running 17.0 for about 2 months
Old 11-16-2004, 01:20 PM
I found a boost leak on the intercooler fixed it the car ran fine for 2 min and started running like it hit a wall again. The problem is i hear the egt probe banging around in the up pipe still I dont know what damage it could do could it chew up the exhaust turbine on the turbo?
Old 11-16-2004, 01:30 PM
RussB's Avatar
yes, it could damage your turbo. but the bigger problem is that your car ran hot enough to melt your EGT sensor. that was probably caused by the combination of the MBC and intake on a stock ECU.
i would suggest getting any check engine light codes read and getting a compression check. if you do take it to a dealership, let them know about your mods as they were most likely the cause of this and that will help them diagnose and fix the problem. don't be surprised if they deny any warranty claims due to the mods... you play, you pay.
RussB is offline
Old 11-16-2004, 02:30 PM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
with 17 psi your fuel would have cut off without a FCD or new computer. sure it was 17?
Cyrus923 is offline
Old 11-20-2004, 02:01 AM
ya the guage said 17 i dont know its a good guage. Im still tring to fix the car im ripping off the turbo tomrrow ill see how the turbine looks.
Old 11-21-2004, 12:14 PM
thanks alot for your help it sounds like we have encountered the same problem. Ill check the cat. im just so surprised that at 10500 miles this could happen. I was getteing 546 (egt high bank A). So thanks again and ill tell you how it comes out. Tom
Old 11-21-2004, 09:06 PM
Im takeing the up pipe off tomorrow. What should I look for in the cat., anything that I'll notice? Thanks Tom
Old 11-21-2004, 09:19 PM
wrx10404's Avatar
Car Info: 04' wrx
You should have searched before you put on that MBC and CAI. Your egt's were probably through the roof ,thats why you probably fried your cat in the uppipe. You probably won't notice any engine trouble right now but i bet your pistons are happy your back to stock. If the uppipe cat is the trouble i would get a catless uppipe and save for proper engine management. I had my stock uppipe on for 15k and 10k was with a cobb stage 2. I have had no troubles like this and i also have an 04'
Also 17psi with no extra fuel is crazy.
wrx10404 is offline
Old 11-22-2004, 07:19 AM
i should not have ran so much i went by some of my local friends with rex's some have the UTEC some dont but im def. getting it ASAP. Thanks Tom
Old 11-23-2004, 12:02 AM
What should i expect if i go catless without the Utec, I'm sure the computer is not going to like it right. Alot of codes I would think?
Quick Reply: Back to stock 04 still wont rev past 5g
