anyone running aftermarket downpipe without brackets
i instlaled my PDE downpipe and cant get the 2nd bracket from the turbo to line up with the downpipe. I cant even get all the bolts and nuts loose on the bracket to the tranny to come loose. Is it ok to use the downpipe with out any brackets? I dont want to force it and cause a leak.
thanks
thanks
Stromung catless dp, couldn't line up tranny bracket, rattles from time to time. When I have my uppipe installed I'll either have them fasten it or grind off the bracket on the dp, whichever SXPi recommends.
Perhaps not 100% needed, but ponder this:
Subaru engineers with a plethora of engineering degrees and centuries of design experience between them use six mounting points to hold up the stock exhuast: Turbo, downpipe, midpipe, axel, and two at the muffler. I'm going to say this frankly: they know more about this stuff than any of us, and they designed it with six mounting points. Now, an aftermarket system is gonna weigh less, and the downpipe mount seems the most disposable of the bunch, but when you think about it you have just removed over 16% of the exhaust's support, and the other mounting points now have to take up that slack. Is it safe? Most likely. Is it really not a big deal? Probably, but IMO it just isn't worth even the remote chance of the exhaust falling off of the car and possibly snapping the housing off of the turbo and bending the turbo/uppipe/header assemblies. You're probably better off to just do it right and use all six points, there's no reason not to and no downsides to doing it.
Hey Guys,
If you're having problems with the alignment of the transmission bracket on the PDE downpipe, please read the installation instructions provided with your downpipe.
There are very specific instructions included regarding this very situation, and not complying with them may shorten the lifespan of your downpipe by adding undue load at the turbo flange.
Please go back and read your instructions, you'll find that the fix is very simple, and in our opinion, very important.
If you have any further questions, please contact me directly at Sales@pde-usa.com.
Regards,
Ian Stewart.
PDE Inc.
Regards,
Ian Stewart.
PDE Inc.
CLsmooth71
02-28-2011 12:24 PM
Vishnu
11-11-2004 10:00 AM
dRu18
08-15-2003 04:03 PM
