AEM bypass valve
Car Info: 2004 White GDB
the bypass valve opens up when the engine is struggling to get air into the intake manifold. (this usually happens when the filter is submerged under water, the bypass valve is to prevent hydrolocking the engine.)
In a car with turbo, the turbo is sucking the air from the filter harder than a NA motor would, thus the bypass valve would think that the filter is submerged under water.
split2nd
12-17-2011 12:06 AM
twistedsymphony
02-18-2003 10:21 AM
