Ack! smoke from my engine???
Car Info: blk 2002 wrx
So i was driving around yesterday for a while, and when i got home, i shut off the car, went inside for a bit... and when i came out, i noticed there was some light smoke wisping out from the engine compartment!
upon opening the hood, i noticed it seemed to be coming mostly out of the front passenger side of the engine, around where the air filter box is.
anybody have this sort of experience? it seems like a bad sign...
help!
help!
Yeah you can look it up all over that other web site.
From what I can tell its either coolant or oil dripping from the turbo's hookups to those systems falling to the bottom of the turbo's heat shield.
Some people seem to get this a lot, some never, and some only sometimes. I'm in the last category, and honestly, I'm not worrying about it. I tend to think its oil at this point. It used to smell sweet to me (which would indicate that its probabaly coolant) but now it smells more like oil. I find this happens most after I drive hard and do not let the engine cool down slowly by idling (with a turbo timer, in my case). My theory is that there's a lot of pressure in these systems and due to some flaw in one or both, with all that pressure coming to an idle turbo the fluid's got no where to go but to leak at the point of least resistants: just above the bottom of your turbo's heat shield.
I must say that I don't have billows and billows... but sometimes its more than I'm comfortable with If you're still worried, get it checked out. In the mean time check your fluid levels.
jason
jason
I have the same thing happening to me. But I'm almost positive that it's either Oil or coolant, or both. The reason I'm positive is because we did a Stage IV conversion on my car, and ended up tearing the gasket on the Oil Outlet pipe to the turbo. So I know I don't have a great seal there. One of my friends described the smell as, Like carb. cleaner. Never smelled the stuff personally....... but I do know that I get little whisps of whitish smoke coming from the turbo. Not terribly worried about it...... but I am making a mess with the small amounts of oil I'm leaking.
Blue
Blue
