5w30 --> 10w30
Car Info: 2004 White GDB
5w30 --> 10w30
I've been using Mobile1 5w30 on my rex for the past 18k miles. However, my last visit at Costco, they ran out of 5w30, so I bougth some 10w30. Are there any downsides to the switch? The switch is going to be temporary only for about 3-6k. I know that switching from dino oil to synthetic and back can be harmfulll for the engine, but I'm not sure on switching the viscocity. Thanks for the responses.
There's a graph in your owner's manual which shows the temperature range of various oils. Basically, the first number (a 5 or 10) is the weight of the oil when cold and the second number (30) is the weight when warmed up. In general, the smaller the difference between the two numbers, the more stable the oil is.
in the bay area 5w-30 or 10w-30 will work just fine.
the only difference is that 10w-30 is a little bit thicker. how does this effect things? during colder weather its harder to get the oil moving during a cold start up. but it doesnt' ever get cold enough here to have any issues.
Car Info: 72 Vespa with curb feelers
Car Info: 02 WRB WRX and 99 WRB RS
I put in an oil pressure gauge last spring and on 5w30 in the summer it never goes above 90psi at startup. But now in the winter the gauge gets pinned (100psi meter) which makes me wonder if I should get 0W30 for the winter.
oil pressure is determined by the pressure release spring, at the end of the day oil viscosity should not effect oil pressure with a fully functioning pump since the pump is supposed to be able to outlfow the motors demand and maintain pressure, therefore the only way to change oil pressure on a fully functional system should be to change the oil pressure release spring.
therefore any change in pressure is due to other factors, and not oil viscosity.
Originally Posted by HellaDumb
In the bay area you can run a straight weight oil, such as SAE30, of SAE40. It's even listed in the manual.
hiphopp
07-22-2005 09:06 PM
pleue
09-24-2004 09:53 AM
