2 stupid newb. questions, but no answers found .....
Old 05-17-2004 | 11:21 AM
esracer's Avatar
Car Info: 2002 Honda S2000
lol don't worry about being flamed.....ok first off....
The bov: You might want to take it apart and clean it and lube it up again.....bov's sometimes need to be cleaned once in a while. That might solve your problem...or just make sure it's installed properly.
No cats: Ok the up pipe is basically meant just for cold start up......you have the car warmed up and you will still pass inspection if you still have your other cats. You can use a resistor to make sure you don't throw any codes with the catless up pipe. When you go to inspection what I will do is I will install my stock downpipe back in, it's not that much work really. If you have any more questions....just post away!
Old 05-17-2004 | 01:08 PM
bone324's Avatar
Car Info: '02 WRX WRB
Switch the BOV back to stock, you can probably find a used on here for cheap or on NASIOC. You can always switch your exhaust back to stock for emissions testing if your worried about cats. I have the Pony Express MIL Eliminator and have never had a CEL.
Old 05-17-2004 | 04:07 PM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
I also suggest changing the BOV back to stock. The most power you can hope to make from an aftermarket BOV is zero. On a car running less than 20 or so psi of boost, it's only benefit is aural bling.
For those new to the WRX, these FAQs are good reading:
http://forums.nasioc.com/forums/show...hreadid=445812
http://forums.nasioc.com/forums/show...hreadid=443943
joltdudeuc
10-11-2008 01:29 PM
ProjekBluBuk
10-03-2007 12:00 AM
RC000E
11-27-2005 02:49 AM
Krinkov
07-06-2005 10:23 AM
jimr
09-29-2004 12:53 AM
Quick Reply: 2 stupid newb. questions, but no answers found .....
