2.2Kohm resistor mod
Whats entailed in this mod. What parts exactly are needed and how does it work? Thanks for the inputs. I did a search but just came up with people saying how good it works and that it is always necessary after an aftermarket uppipe installl is completed. Thanks again.
Ryan
Ryan
Pr0n King
Car Info: Turncoat Turbo
1. Buy 2.2k ohm 1/4-1/2 watt resistor
2. Locate uppipe
3. Locate sensor (EGT) in uppipe
4. Remove connector from EGT sensor
5. Place leads from resistor in sockets in connector.
6. Tape in place/do what you can to waterproof connections.
7. Either disconnect battery/use OBDII scanner to reset codes/or go through 3-4 drive cycles to extinguish MIL.
Voila...
__________________
2. Locate uppipe
Voila...
__________________
Pr0n King
No problem! Let usk now how it goes...
__________________
__________________
thanks for the link..i have been in contact with Tom and most likely going to order one . But really.. for the fellow I-clubbers and do it yourselfers...im sure someone out there has the exact wiring diagram, parts, etc for this fix that all of us can share.
Wingless Wonder
03-22-2005 12:07 AM
Smooth_Ej20
01-19-2005 09:42 AM
spdkills
09-30-2003 11:28 PM
