18G vs. 20G
18G vs. 20G
In the future after I upgrade my tranny, I plan on doing a turbo upgrade. Currently Im looking at the 18 and 20G turbos. Im thinking I would like around 320ish WHP. How much difference is there between the two turbos? It seems that most 18Gs are making around 300WHP. I was also wondering how benificial headers would be at this power level. Are stock minifolds ok? Any suggestions would be greatly appreciated.
Originally Posted by Texas WRXer
If you did it over again would you go back with your current setup? How laggy is the 20G?
currently I hit full boost ~21psi at around 3500rpm in 3rd gear & up...
As far as a manifold, with a turbo this size, your motor would definitely make more power with an aftermarket manifold. Because that turbo pushes so much more air, headers will be able to help that turbo out substantially. I would expect to see gains of ~15 WHP and ~20 WTQ with our Gruppe-S V2 header on your setup.
Thanks,
Geoff
Car Info: 00 BRP RS LIC'd 01 EJ207 + non DCCD 6 Speed
testes1010 is also not in CA, and probably running 93 octane. But still, 21 psi at 3500rpm from a TD05 20G is pretty amazing on a 2.0L if true.
Geoff,
What would the typical spool characteristics be on a 2.0L with the TD05 20G and the TD06 18G? Say supporting mods are turbo back, header, uppipe, injecotrs of course, etc. just the basics. Im still trying to decide on a turbo for my Ver. 7 STi and I think this info would help Texas WRXer as well. Have you guys dyno'd any cars with a similar setup?
Geoff,
Geoff,
Geoff,
Originally Posted by Imprezer
Pew-pew...
It's all about TD06SH-25G with 10cm^2 housing... That's what the big boys run... Muahahah
Geoff,
Geoff,
Thanks,
Geoff
Admin v2.0
Car Info: 02 Black Legacy GT
On my regular stock EJ20 I hit full boost at 5300PRM. Kinda late, but i don't mind. The payoff is great. I am yet to see another car to hit 312WHP on pump gas at Shiv's dyno. Then I tried in on a built 2.4L with AVCS heads with AVCS no hooked up. Spool up was complete by 4800PRM. Now, I have Spec C engine. Let me just tell you that it spools up very nice.
For your amusement, here is a pic of my T67 (25G) vs. BOZZ Speed XP+5 (modded VF34).
Haha...
Haha...
mirraflair
08-31-2006 02:45 PM
