What's the best MBC out there?
ok so here's the thing, I had a MBC on my car for about 2 years, and recently even at the lowest level it would spike up to 1.5 bars. So i figured the spring inside is screwed. I changed it back to stock yesterday, and when i floor the boost only goes to .5 bars (about 7-8 pounds) Does this sound right with stock boost? I thought stock WRX's ran at 14 bounds. Anyone know what might be the problem?
Were you in the lower gears? I don't think you can hit 14psi unless you're in 3rd or 4th. Also, maybe you should check your hoses and connections. Does it feel like it's boosting 8psi?
:banana:
:banana:
