Tachometer problems
Tachometer problems
I recently installed an aftermarket computer and am having problems getting the tachometer to work.
Does the tachometer send a differnt signal than the rest of the guages? Is it digital or analog?
Any help or suggestions would be great.
Sarcastic Jackass
Car Info: i drive a beater
What type of car? Are you sure that you connected the wiring for the tachometer correctly?
I've encountered this before and that what it turned out to be. With the older style ignition packs that sat on the top of the intake manifold, one of the wires was the line for the tach.
grex767
05-27-2006 10:37 AM
rs-scooby
11-11-2003 04:52 PM
stealth-wrx
03-09-2003 11:37 AM
