Sti injectors, low or high impedance?
Hello all,
I have recently added a VF22 w/ball bearing center. I need to upgrade injectors next along with a fuel pump. After that I planned on going with the ECUTEK re-flash.
My question to you guys is can the stock ECU run high or low impedance injectors? I have read that the STI injectors are the opposite of the stock WRX injectors.
Thanks in advance to all who respond.
Jose
West Palm Beach, FL
Jose
West Palm Beach, FL
Jose,
The STi injectors are the same impedance as the WRX injectors. It wouldn't be cost effective for the manufacturer to have different systems for the same car. You have a good combination and should have power in the high 300s depending on a few other pieces. Also the power is so much more linear with the ECUTek than with a piggy-back. We have done quite a few here at the dealer with mostly the smaller VF30 and 34s and the customers have been very happy with the results.
I hope this helps.
Troy
I hope this helps.
Troy
lude93
12-21-2004 08:28 PM
