stand alone engine management
Can someone please tell me exactly what is a stand alone engine managment system? is it replacing your entire computer? or can u simply add a piggyback to take over?
I understand an apexi air/fuel managment computer is different....but wouldnt this be part of it? as you can CONTROL the settings as u see fit.
Originally posted by sigma pi
does the stand alone know how to work ac and gagues and other stuff or do you lose some stuff
I had a LINK ECU and it did know how to work everything for the most part. There was nothing lost AFAIK.
Does the Link come with proper setup so that I can kick start right away?
I alwasy had the feeling that you need to spend extra bucks to go to performance shops for some dyno tuning. How hard and more importantly, risky, is it to tune it yourself?
You do however have to have the serialLINK to hook up to a laptop for tuning or have the handheld module for tuning.
Can you break things? Most definietly.
To get the most performance, should you take it to a shop? That is debateable. However if you are torn between a standalone and a reflash.. A standalone is not for you.
think0rz
04-25-2005 10:51 AM
IllNastyImpreza
09-29-2003 08:06 PM
