safc II airflow sensor type
hi all, i need a bit of help setting up my safc II. i am running a 2.2l n/a high compression engine in a 93 legacy.
i have already wired up the safc, and it appears to be working correctly. what i need help with is setting up the type of air flow sensor. just so you know what i am dealing with, i am using a safc II and trying to tune it with a safc I manual. where you input the sensor no. it looks like this:
Sens. no
IN OUT
01 01
according to the app chart the legacy uses a HW 10 sensor. does this mean that i sould change the screen to read:
sens. no
IN OUT
10 10
also, to toggle the original safc between setup mode and running mode you press the foreward and backward buttons at the same time for .5 seconds. however, the safc II has a joystick-like control with a **** around it. how do you toggle the safc II between setup mode and running mode?
sorry about the long post, but i want to make sure everyone can tell what i am talking about.
thanks in advance for any responses,
josh mould
Sens. no
IN OUT
01 01
sens. no
IN OUT
10 10
josh mould
ideas?
does anyone have any idea what i am talking about? if i am not being clear enough then i will elaborate further... this is something that i dont want to make a mistake on... if no one knows what i need to know exactly then how are the sensor types set up for different subaru models?
dont want to screw this one up!
thanks for any replies,
josh mould
josh mould
Car Info: 2001 sub. imp.
hey, ill look tomorrow at what i have mine set up as. i also have a 2.2
i havent touched mine in a while, but to get between setup and running modes, you have to toggle back to the main screen and go into the monitor section, then if you want to tune, go to the settings section
thanks
when i got my safc II the only english directions that apex had on the net were for the original safc. i went back there last nite and they had the newer directions posted. i was getting pretty tired of trying to compare english safc I directions to japanese safc II directions!
anyway, turns out that i had my hot wire settings correct. thanks for the help!
josh mould
josh mould
rau
10-22-2003 02:06 PM
audiofreak
10-05-2003 07:42 AM
