recent crappy gas mileage - bad MAP sensor?
Crappy Gas Mileage
Well here we go, so i have owned my WRX wagon for a few months now and recently my gas mileage has just turned to crap, when doing my oil change the other day i hooked my car up to my scantool and wanted to look at fuel trim data. Well Long Term and short term fuel trim was very normal so i looked at some of the other data. The pressure sensor showed only 11inhg, I was freaking out. So i broke out the old vacuum gauage it incidate i had 21inhg so no mechianical issues so i suspect a bad pressure sensor. I was wondering if anyone had run into this problem before i know that the small peizo crystals bend over time but i did not know if it was a problem.
thanks matt
thanks matt
Yes, you are correct that it's real time and is used by the ECU to determine boost, but it's an absolute measurement. Your gauge is relative to atmosphere so the readings will differ by whatever the atmospheric pressure is at the time.
Sup guys, here's a thread in Hawaii about Gas Mileage Survey!! Check it out guys. Hope this helps.
https://www.i-club.com/forums/hawaii-43/gas-consupmtion-survey-133156/
