QPD - Hydra EMS Engine Management
Hi Guys, it has been awhile since I surfed this Forum let alone post in it. This is Andrew from Quantum Performance Development. Just a refresher, we are a Link Distributor that makes PNP units for the 98-02 Impreza 2.5RS. Anyways we are developing a new PNP ECU that will be Launched at SEMA this year at booth 12948 as Hydra EMS. We are looking for Volunteers to help us build base maps on ATP's All wheel Dyno with the Load basing Option enabled. Cars we are looking for:
98-02 Impreza 2.5RS Turbocharged
02- Wrx Modified
03 WRX STi
We only need a few cars in each category. First come first serve...
All Volunteers will get substanial discount on our units. Call or email us for details.
A few of the features of our ecu are:
Dual 16bit 25mhz Motorola Processors for fast and accurate control
32x32 Fuel and timing maps configurable by load and RPM
Anti-lag and Aux Fuel Fueal and Timing Maps
onboard 3 bar map sensor good for 30psi
coolant and air temp correction
Optional Barometric Correction with 1 bar map sensor
Drive by wire capability
Optional Autotune mode with Ntk Wideband Sensor
too many other functions to list...
For More Information on our new ECU, check out www.carmodifications.com
Andy
02- Wrx Modified
03 WRX STi
Andy
