PE1820 and UTEC Owners... I need your help VERY urgently
Guys,
I have the following setup on my car:
PE1820 turbo (V2)
STI injectors
Walbro FP
uppipe
turboback
k&N panel filter
Gredy Profec B
Stock Intercooler
stock hoses
Can anyone possible pass along a map that would work with my car? I used the search function, and came up with only one PE1820 map, but that setup seems radically different from what I am running.
I am going to pick up the UTEC on Monday, so I have been scrambling to read the instructions on-line to try and understand how it all works, but I have absolutlely NO IDEA where to start as far as a base-map to work from.
ANY help that you guys would provide would be VERY much appreciated.
Thanks in advance for your help and suggestions.
PE1820 turbo (V2)
STI injectors
Walbro FP
uppipe
turboback
k&N panel filter
Gredy Profec B
Stock Intercooler
stock hoses
Car Info: 09 E90 M3 SEDAN w/DCT
Wackie from WRXhackers.com has a map. Only thing is that he has a Blitz FMIC.
If you call Mark from TXS, he will tell you where to pull the timing for the stock intercooler.
Good luck,
Andy
Good luck,
Andy
NOXQS
09-14-2005 01:28 AM
