Opinions on ECUTEK
Old 01-16-2003 | 08:02 PM
Xero's Avatar
Car Info: Soon to be a 2011 WRX?
Yeah Chris... That would seem appropriate, but I believe most of what I've been seeing (albeit NOT from I Speed) is listing flat rates.
If the cost is actually relative to the time you spend with each car on a dyno and the tuners time then we're talking about a fair trade. Money for service.
If we're talking about an off the shelf map being plugged into each car with no dyno time then I call it a rip off.
Thanks for clarifying... If you can clear this up for me, at least in terms of how I Speed handles things I'd appreciate it.
-Alan
Old 01-16-2003 | 09:22 PM
Vishnu's Avatar
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
Originally posted by ShotgunTC88
By the way VISH,
Im NOT knocking the initial reflash,
Just the flashes if we have to change up/down because of boltons or boltoffs (emmissions)
(pain in the *** for yearly tests in some states. )
You da man!!!
Be seein ya soon!!!
Shotgun
Hi Shotgun,
Our charge for successive re-mapping is $175, not $275. We charge this amount to offset the time and effort we put into our map calibration process in addition to the time it takes to actual conduct the flashing process. Not to mention my impending lung and brain transplant from inhaling exhaust fumes all day on the dyno. Making effective and safe maps isn't a trivial affair. Fortunately, we do a lot of in-house ECU re-mapping so per-unit costs are reduced substantially. Also, as with every tuner offering, we assume a degree of risk when offering our services or parts to the public. Not charging fairly for a service or component would be question business practice.
Cheers,
Shiv
________
Stobart Motorsport
Old 01-16-2003 | 09:40 PM
wrxtuner's Avatar
Car Info: 2005 PSM STi
Originally posted by Vishnu
Hi Shotgun,
Cheers,
Shiv
I agree with Shiv about the environmental hazard. I WOULD NOT want to be in his shoes breathing the fumes and listening to the noise when the dynotuning is occuring. During my dynotuning, I had to leave a couple of times because the fumes and the deafening noise (that's when he pointed out the ear protection hanging right in front of my face, Shiv doesn't use one). And all this was with cool weather. Summer must suck.
Old 01-16-2003 | 10:59 PM
Xero's Avatar
Sorry Chris... I wasn't clear in my last post.
I didn't realize that getting a reflash included actual dyno time for each car.
So if everytime that I get a reflash I actually get my car onto a dyno with some tuning done (even if it's just some tweaks done to a base map that you in your experience have established as a decent map for my mods) then it is NOT a rip off.
Sorry if I was being unclear and thanks for taking the time to respond.
-Alan
Old 01-19-2003 | 11:45 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Originally posted by arborwoodie
Shiv,
I can relate to Shotgun's concern about the emission tests. If you haven't planned to do this already, I have an idea that may both benefit your loyal customers and your business.
If you can keep available a handful of stock WRX ECU's for 'rental' purposes. These can be 'rented' out for say $40-$50 for 2 weeks (plus shipping and core deposit) for your 're-flashed' customers (and may be a bit more $$$ for others not tuned or reflashed by you).
This should help with the emission issues for us once per year or 2 year. It wouldn't require any more reflashing effort or $$$. It will definitely be more affordable to us and could also be a source of easy income for your company.
If you like this idea, I wouldn't be opposed to a small discount when I am ready to order your reflashed ECU.
Regards,
Henry
Why bother when we have the i-club and good friends? ask one of your subaru buddies to borrow his ECU for a couple hours do your test and return back to your own ECU.
Old 01-20-2003 | 05:54 AM
Wingless Wonder's Avatar
<snip..>
<snip..>
I don't think this would work the way we'd like, Henry. I think there could be a lot of trouble from the CARB and BAR if a shop were to blatantly circumvent state law regarding emissions testing. A second problem would occur at the test station when they compare the VIN of the vehicle to the registration - I think they check this to make sure the vehicle they're testing hasn't had a license plate swapped.
I think we're better off taking care of the problem ourselves. These mods are sold with the understanding that it is for 'off-road use', only. My WRX is never driven on public roads.
The XEDE control system looks like the hot ticket for keeping different engine maps handy.
^ww^
Old 02-10-2003 | 06:48 PM
SC WRX's Avatar
Car Info: '02 WRB WRX Wagon
Re the second problem you identified: What did you mean about comparing the VIN to the registration. Not that I condone it, but I think the poster meant, hypothetically, if one was about to get his car smogged, he could swap ecu's with someone with a stock ecu, pass and get smog certificate, then swap back. Wouldn't that work, or does each ECU have the car's VIN programmed into it?
On a different note, how stealth is the ECUTEK?
Other than the butt-dyno difference, would a service tech be able to detect whether an ECU has been reflashed? If so, how much trouble would that tech have to go through to figure it out? Would he be able to tell by accident, for example, just by checking for CELs, or is it something you specifically have to look for?
Finally, would an otherwise stock WRX with an ECUTEK'd ecu pass a CA smog test?
Thanks in advance for your help. This discussion already has been immensely helpful.
Quick Reply: Opinions on ECUTEK
