need help with fuel upgrade?
need help with fuel upgrade????
im running an ihi vf 30 and its time to upgrade fuel and ecu anyone have any suggestions........ i have turbo back , aem intake, stromung down pipe, godspeed up pipe, greddy bov, samco inlet, avcr boost controller, greddy tt, short shift, kyb agx, whiteline sway bars, cusco strut braces if that helps 02 is the year
If you want to tune it yourself, there's the UTEC. Using Search function will find numerous references to the UTEC.
COBB Tuning offers the AccessECU re-flash, with many off-the-shelf tuning maps to choose from. There are also maps for CA gasoline and other states' 93-octane fuel.
Just now shipping (pre-orders first) is COBB's AccessPORT, which allows the end user to remap their own ECU without having to ship it to a facility for a re-flash.
The EcuTek re-flash works great but you might consider getting a custom tune from a local shop with a dyno, so they can compensate for that aftermarket intake.
There are maps from COBB Tuning (AccessECU and AccessPORT) and Vishnu Performance (EcuTek) that work with the VF30/VF34, uppipe, and the catless turbo back exhaust, but not an intake (see thread on intakes debate in WRX Powerplant forum).
With proper engine management, you can move away from those third-party boost controllers and supply proper fueling at the same time.
Car Info: $200,000 sports car
well, if you ditch the intake, BOV, and AVCR and install al walbro pump and STi injectors you'd be a perfect candidate for the Cobb stage 2.5 reflash. with a reflashed ecu whether it's a cobb reflash or a EcuTek reflash, you will notice a much smoother powerband and your car will be much more fun to drive.
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
I talked to a Cobb tuning tech and I have an AEM cai. He said they recomend going back to the stock intake because the AEM doesn't give the MAF sensor consistant readings.
sUbEe
09-16-2004 04:32 AM
SubySal
12-03-2003 08:22 PM
1Slow///M3
09-05-2003 07:28 AM
JohnB
06-30-2003 12:14 PM
aWrxer
04-23-2003 10:37 PM
