Misfire HELP!
Misfire HELP!
I bought a unichip from my friend and I have had some CEL problems. The code reader says my vehicle is misfiring on cylinders 2 3 & 4. This CEL only comes up when I launch my car hard. The car also pulls up the code P1446 for the in fuel Tank sensor. Will these problems eventually hurt my vehicle, or can I drive it like that.
Help
Eric
Help
Eric
Because the amount of weight that is placed on the crankshaft I believe, because when you lighten the flywheel, it changes the dynamics of the engine a bit and make the engine a little "looser" if you will. I would also assume that the harmonics change also. Because like underdrive pulleys, the weight of the flywheel and pulley is designed to work such that it acts as a harmonic dampener.
It is like saying, I have misfires on all four of my cylinders. But is it really misfiring? I do not think so. Subaru is supposed to come out with a reflash for the misfiring issue.
Here is a good article about underdrive pulleys:
http://www.dinanbmw.com/html/danger_...er_pulleys.htm
Siper2
58
05-03-2006 08:38 AM
wonton2049
11-14-2004 03:25 PM
